Truma C6002 EH
F.d. 16636
Been going through the manual for the heating unit. My question is, can you run this heating system on just the electric ( 220V) without the gas turned on and no water in the system. Or must you have water to heat with? or is it electric fan heated air?
I was reading the instruction, but its not vary clear on just using 220 outside power, with no gas. If I understand this correctly, its a warm air system using both gas and electric. I have no need of the water heater just now, I was looking for just warming the cabin to keep it at 10 or 15 degrees
Yeahh yeahh ...newbee.... don't laugh:twitcy:
Maja
Arvika
Sv: Truma C6002 EH
Hallo Rustygun!
The answer is YES! Just put the outer cirkel on the upper instrument on one or two steps of electric heating and the downer instrument (with thermostat) pointing to the sign for just heating and than use the thermostat (?) to adjust the temperature.
Is my schoolenglish clear enough? - otherwise we can perhaps take it in swedish. I´ve understood that you understand swedish pretty good.
Best regards from Värmland
F.d. 16636
Re: Sv: Truma C6002 EH
Hallo Rustygun!
Tack!! school English var perfict!
Ok skall försök i morgon. Jag proved det en gång, men det starta aldrig. Kanske gjorde nog fell:p
F.d. 6238
Sv: Truma C6002 EH
Hej på Dig R.G.
Där ser Du. Kanske skulle vi börja att prata svenska med varandra. Du pratar ju jättebra Svenska, och skulle Du inte kunna förklara Dig vad du menar så kan vi övergå till Svengelska.
En liten bit svenska, en liten bit ENGELSKA.
What do you think about that!!!???
Ha de bra hälsningar från Kurt.
:twitcy::twitcy::twitcy::twitcy:
F.d. 16636
Sounds skit bra med Swinglisk Kurt! i värsta fall jag kan go back to my yank språk when I need technical help..:p
dessa Truma "handbook" till example:D ( Thank God there is Scotch)
